Double input event on keys on UHK 80?
Have any of experienced your UHK 80 produced two input events when pressing a key? For instance, typing ‘e’ becomes ‘ee’ or hitting SPC produces two SPC events?
I experience it sometimes, and it is very random to me. If you have not experienced it, do you know of easy ways to debug the signals from the MC on the keyboard or similar to dig further into it?
This is often a switch issue.
First try to reseat the switch: pull it out, bend its pins a little bit, push it back in. So that they end up tensioned against the sides of the hotswap socket.
If that doesn’t help, then generic troubleshooting guide is here: Troubleshooting repeated and missing keystrokes - Ultimate Hacking Keyboard
Thanks for the hints. I’ll try it out.
