My UHK regularly drops a connection to it’s only host, my Mac.
How can I re-trigger that connection/pairing from the UHK? The only way I’ve been able to do this right now is to literally drop the device from Mac, reset the board via the button underneath, and re-pair it. This is obviously not great and I’ve resorted to just using a wired connection.
There is the reboot command which you can use instead of reaching for the reset button.
I would expect that forgetting the connection in mac and trying to connect to work. If not, feel free to open a ticket, although at the moment we don’t have a simple way to pull bluetooth logs from the UHK. (Although that feature is implemented on the firmware side already.)
