Is there a way to get a “heatmap” like feature in the UHK Agent? Similar to Introducing Heat Maps
I can vaguely remember that we considered this feature, but we haven’t made any progress, and I doubt it’s worth allocating resources for it.
Would be interesting information… but probably better things to spend time on..
I have to admit this is pretty cool though https://www.youtube.com/shorts/du34yIqjivc
Well, do you really want a tap on a key to make all nearby keys hotter? I would expect for statistical purposes not.
Anyways, it shouldn’t be hard to implement. I would almost say ideal beginner project
You could use a keylogger (not the bad ones
to gather that information. There are several programs for that. I used one for a while to see which keys I press most.
Could you recommend a keylogger that meets the following needs?
I’m looking for a tool that can:
- Log both individual key presses and key combinations (e.g., Ctrl+Alt+P)
- Record the exact timestamp when each input occurred
- Capture the active window title or application at the time of each key press or combination
Ideally, it should work reliably on Windows. Thank you!
