How do you suggest to resolve the ambiguity between ifDoubletap that looks into the past and ifDoubletap that looks into the future?
More thoughts:
ifFollowedByTapSequence => ifSequence
ifExtendedToChord => ifChord
Linguistically, FollowedBy refers to future keys. (The opposite would be PrecededByâŚ)
ExtendedTo also means that this key is already active and the next keys listed would be the (future) extension.
Or:
ifFollowedWithChord => ifChord
ifDoubleTap into the future would be an ifFollowedBy $thiskey?
The other one would be ifPrecededBy $thiskey.
Still not intuitive way to write a ifDoubletap. Exactly the same problem as with ifGesture. You have to start thinking about workarounds before you have even a chance to decode it.
When would you want to match a future doubletap?
When would you want to match a past doubletap?
What are the use cases?
Have you not read the initial posts, or are they so unintelligible? :-/
holdLayer fn
ifDoubletap toggleLayer fn
holdKey iLS //act as a normal left shift
ifDoubletap tapKey capsLock //lock "shift" by doubletapping shift
I donât have a real-life example of mine, but clearly rpnfan has one in the first post.
For an artificial one, assume I want a key to produce âbâ on tap and âaâ on doubletap.
ifGesture $thisKeyId final tapKey a
holdKey b
Or from constraints standpoint:
When I donât want the side effect of the first tap, but donât mind waiting.
If I donât mind the side effects of the first tap, but want it to work in real time.
Looks like the current version of ifDoubletap matches the usual use case nicely.
If you want the more sophisticated âignore my first press for a bit and wait for moreâ then you use ifSequence.
In the documentation for ifSequence and ifChord you would describe that they will delay the press a bit until more info or timeout is seen â just like ifSecondary/ifPrimary (advanced resolution strategy) may delay a bit.
In the documentation of ifDoubletap you would describe that they look back at previous activations but wonât suppress or delay those.
You could make the doubletap case clearer by naming it ifPrecededBy.
So you would end up with:
// looking at past keypresses:
ifPrecededBy $thisKeyId = ifDoubletap
ifPrecededBy ...
// looking at future keypresses:
ifFollowedBy $thisKeyId = ifSequence $thisKeyId
ifTogetherWith ... = ifChord ...
That makes a nice table (or maybe it doesnât? but Iâll tryâŚ).
| which key | looking at past key taps | looking at simultaneous key presses | looking at future key taps | looking at timeout |
| (separate taps: each key pressed and released individually) | (chord: all keys pressed and held down simultaneously) | (separate taps: each key pressed and released individually) | (key held down for longer time) | |
| other keys (long version) |
ifPrecededBy keyid |
ifTogetherWith keyids⌠|
ifFollowedBy keyids⌠|
| other keys (short version) |
ifAfter keyid |
ifChord keyids⌠|
ifSequence keyids⌠|
| other keys (legacy name) |
n/a | ifShortcut keyids⌠|
ifGesture keyids⌠|
| same key | ifDoubletapor ifAfter $thisKeyId |
n/a | n/a | ifHeld |
The commands in the columns âsimultaneousâ and âfutureâ keypresses will delay the macro and wait for more keys (up to a timeout).
- if the condition is reached, the corresponding macro action is executed, and the keys pressed so far are swallowed.
- if the timeout is reached, the individual keys pressed so far are activated (played back).
Does this make any sense?
Will it be clearer in this tabular form?
Burn my ideas if you donât like them. I am wearing asbestos.
Well, lets say that I am not convinced.
I have to take more time to read and grasp all posts fully â as I am not confident with the different command yet.
But a quick feedback on the idea of the table. I think that is a great way to make it clearer what each command is affecting. Another idea is to draw a timeline and visualize some examples.
Throwing in some more words to see what may stick (so I donât forget my brainstormâŚ):
| condition | meaning | direction |
ifTappedPreviously |
doubletap | past |
ifTappedAgain |
doubletap | future |
ifTappedBefore |
doubletap | past |
ifTappedNext ... |
tap sequence | future |
ifAlsoPressed ... |
chord | future |
Canât stop thinking about this. There has to be a way to make this clear and easy to understand.
New idea:
What if ifDoubletap just got a qualifier, like the advancedStrategy or simpleStrategy qualifiers for ifPrimary and ifSecondary.
ifDoubletap pastStrategy ...
ifDoubletap futureStrategy ...
If the strategy field is omitted, it defaults to pastStrategy, making the behaviour backwards compatible.
If you really wanted, you could make the defaultDoubletapStrategy configurable (e.g. from $onInit), just like the defaultStrategy for secondaryRole:
set doubletap.defaultStrategy past
set doubletap.timeout 300
etc.
I think Iâve reached a conclusion for me. This is as far as I can bring this for now.
@rpnfan What do you think about this table?
| category | examining past keys | examining simultaneous keys | examining future keys | timeout |
| taps, chords, or hold | separate taps: each key pressed and released individually | chord: all keys pressed and held down simultaneously | separate taps: each key pressed and released individually | key held down for longer time |
| execution strategy | executes immediately | delays macro execution to wait for more keys (up to timeout) | delays macro execution to wait for more keys (up to timeout) | delays macro execution until timeout or key release |
| buffered keys (held back while waiting) | nothing buffered; previous keys already executed their behaviour | buffered keys are replayed | ||
| commands examining other keys | ifPrecededBy keyidor ifAfter keyid |
ifTogetherWith keyidsâŚor ifChord keyids⌠|
ifFollowedBy keyidsâŚor ifNext keyidsâŚor ifSequence keyids⌠|
(macro execution continues; else clause taken) |
| commands examining same key | ifDoubletap pastStrategyor ifAfter $thisKeyId |
n/a | ifDoubletap futureStrategyor ifNext $thisKeyId |
ifHeldor ifHold |
| legacy commands | ifDoubletap= ifDoubletap pastStrategy |
ifShortcut keyidsâŚ= ifChord keyids |
ifGesture keyidsâŚ= ifNext keyids⌠|
Where there are âorâ choices, my personal preferences for the namings are:
| command | why |
ifAfter ... |
âAfterâ clearly refers to something in the past |
ifChord ... |
âChordâ is something played or pressed together |
ifNext ... |
âNextâ clearly refers to the future |
ifHeld |
âHeldâ is proper English, because a key is held down |
ifDoubletap pastStrategyifDoubletap futureStrategy |
Similar qualifier as for ifPrimary/ifSecondary, defaults to pastStrategy for backwards compatibility |
As an alternative for the doubletap strategies (= easier implementation), one could also just document that ifDoubletap is identical to ifAfter $thisKeyId, and if you wanted the âfutureâ behaviour you would need to write ifNext $thisKeyId.
Iâm taking off the asbestos suit. Burn me.
