I use a GoPro case for my UHK60s, anyone (albeit the beta testers only) found something that works as a case for the UHK80?
I can highly recommend this origami case from FalbaTech.
I ordered the one for my UHK60v2 (with custom dimensions, because there weren’t premade template available) and it’s a very solid case.
Do you have the riser installed?
not the riser80, but i do have the feet installed.
