Trying to find the specs for the uhk 60v2. Can’t find it anywhere. Particularly I’m trying to replace the usb c female connector and want to know what type of usb c connector it is and if it is singularly replaceable, can be soldered, or has to be replaced with a breakout board, etc.
Main reason is my keyboard will flicker off for a second and I’ll lose my mouse function and in that split second may type or erase something I didn’t intend. I’m assuming it’s the faulty connector from damage from strain due to the cable “holder” breaking and not keeping the cable in place. If the pins are ruined or the connector is ajar I’d like to fix or replace it.
