All USB Cables too thick
Hello,
i bought a fancy spiral USB C cable to make the keyboard look fancier but it is too thick to fit the hole, so I was looking for a very short usb c to usb c extension cable which fits the hole, does anyone have a recommendation?
You could just wait for the hole to break, then you won’t have that problem! #inevitable :slight_smile:
Is that so common?
I’m afraid it’s relatively common. Our mechanical design is not great in this respect, but further UHK versions will have no such issues.
Alternatively, you can dremel the case to make way for the thicker cable, but it’s not for the faint of heart.
Future versions of the case?
Or a completely new V3?
I mean a new keyboard variant.
Any timelines on when the v3 will be announced?
I’m sorry, but we don’t have a timeline to share.
Could you elaborate on what this means exactly? Is this just a cosmetic issue, or a functional issue (eg not having a working usb c port)?
Bit in the middle.
The port works but the cable holder snaps and the cables go all over the place. You can live with it but it is frustrating.
I know this is an old old thread, but I wanted to share my findings. I have yet to find an extension that works well thickness wise with the cable snaps. Everything is just too thick. That being said, I did find a really nice (non spiral however) usb-c→usb-c cable that works/fits perfect in the UHK 60 cable snap/holder. IMHO better than the included one because even that one seems to put extra stress on the plastic and inevitable it breaks (like on my first UHK60v2).
Apple includes a cloth black usb-c→usb-c with their black TrackPad, Magic Mouse and maybe other products.. not sure. You can also find them on ebay too.
Again, I know this is old, but I just got my 2nd UHK (for work) and I wanted to try NOT to break this one..:slight_smile:
