Ctrl key keeps getting stuck on built-in hand rest UHK80
Hey guys, I have the UHK 80, which I love, but lately I have this issue where the left control key keeps getting stuck / wedged by the built-in hand rest after pressing it down.
Does anybody know how I can fix this? I tried taking the hand rest off and re-attaching it, but it keeps sliding up and brushing up against the left control key.
Thank you!
Am I correct to assume you have the old rubber palm pads? If so, are they showing signs of warping/bubbling? Can you show us some pics? I had issues with mine stretching towards the bottom-left corner. The rubber hangs over the edge a bit, and as a result, the retention tabs no longer fit into the plastic case.
I recently bought the new wooden ones, and they’re really nice! There’s definitely no way they’re gonna snag the caps, as they’re solid and snap firmly into the case.
they are nice the uhk80 wooden ones, not as nice as the uhk60 ones but still very very nice
I agree. Wooden UHK80 palm pads FTW! They made my UHK80 look and feel just more stylish and refined.
