I found a few other 3d files in the Thingiverse search results:
But I’m wondering of there are any other files that aren’t shared here. I remember seeing some other custom wrist rests, but having trouble finding it again, which is why I created this post, to aggregate all the best, most used, and popular customized accessories for our beloved keyboard.
Thanks for this. Is there somewhere I can find an actual 3d model of a UHK? like an STL file for a mockup of a UHKv2?
For modeling purposes, I would like to create a new riser, as I am using a different 3d printed wrist rest, and the tenting supports that are available are not very good. I’d like to create a new one for the different style wrist rests.
Maybe some different 3D printed mouting plates for the raiser would be cool? I have been thinking about a horizontal version which has different “holes” for the riser.
something like this:
I_._._._._._I
I_._._._._._I
And the riser can be placed onto those dots instead of having to move the riser plates to a new position?
Your solution would make initial experimentation with angles easier. Our solution allows setting up Riser quickly without thinking about the correct adjustment at the expense of initial experimentation. There is no perfect design, only tradeoffs.
If you happen to create a 3D design, we’d love to see it.
