Keycaps for Colemak layout
Would you have any suggestions for keycaps for use with a layout like colemak?
Moving the the stock ones around makes them uneven and I am not ready for blank on Coleman just yet.
I’d go with a flat/uniform profile cap like KAM, XDA, DSA, etc.. That way you can rearrange all the caps without worrying about row heights. Yuzu has KAM profile caps, and FK Custom has XDA. And of course, you can customize the legends with them. :wink: They have templates for both the UHK60 and 80.
I type on Colemak and designed myself some keycaps on Yuzu. IIRC, you can just select default legends for Colemak. Or you can go fancy and really creative with colours and legends. I went with Cherry profile keycaps; I really like the slight bend between rows; I find that makes typing a bit more comfortable.
My set fits the Ultimate Hacking Keyboard UHK60 and you can find it at Yuzu keycaps - UHK Maxtend v1. Photos of an actual production run can be found in this blog post.
Hope that helps!
