Hi, does anyone know if any Keychron keycaps will fit into UHK 60v2 (ANSI)?
Or any other well known keycaps pack, like general one, not customs like from https://yuzukeycaps.com printed on demand.
The problematic keys are the ones on the rightmost column. Backspace (1.5u R1) is incredibly hard to find. You can put a R2 key there which some sets have, but it will be slightly off (different slant / height / row profile). The others (Backslash, Enter, Shift, Control) can be found, but often with wrong labels.
The two space bars can sometimes be found in “Minibars” kits as true convex caps, or you can put some other 1.75u keys on them although they won’t be convex.
See also the links to a number of my Reddit posts in this comment: Where to find custom keycaps for UHK? - #15 by maexxx
I don’t need ALL the keys, generic pack from Keychron/whatever that will skip those 1.5u is fine. I will dig into reddit links you shared, thank you!
If you want to mix and match with the regular UHK keycaps, you probably want to make sure your other non-UHK keycaps are OEM profile, so the height/slope aligns with the UHK keycaps.
Check out the forum thread I linked above for a comment with photos of backlit “Pudding” keycaps. There I mixed them with the UHK dot keycaps.
