Setup: Mirroring, runtime macros, thumb trackball, etc
This is my configuration. This is to convey the high-level idea. I will try to cover specific features in more detail in separate threads.
Base layer
Notice 7890 keys which together with trackball act as regular thumb trackball with buttons on 7890
  • 7890 keys map to mouse buttons, basic tab switching, new tab, close tab, and trackball-scrolling
  • mouse/caps button alone mirrors entire keymap… …so it is possible to write single-handedly.
Mouse layer - arrow clusters
Case buttons activate arrow keys:
  • A-insert is terminal paste shortcut
Mod layer - actual mouse keys (sorry for confusion!)
Case button + mouse/caps button activates mouse key layer
  • A-arrows, C-PgUp/Down are browser history and tab switching
  • C-T C-W are “new tab” “close tab”
Fn layer - symbols and other functions
Right “space” activates symbol/macro/Fkey layer:
  • top row are runtime macros (vim-like style), ~ key acts as vim Q (Q+key starts recording)
  • Emoji contains shortcuts to commonly used emoji alt codes, e.g. Emoji+c+r = cry, Emoji + h + r = heart, etc…
  • Bind allows rebinding part of the keymap:
    • Bind+a - maps arrows onto jilk, and regular escape on the mouse/caps key
    • Bind+m - maps the 7890 keys to regular mouse actions (this disables rocking gestures, middle-hold scrolling and middleclick simulation, but works reliably in games etc)
  • RGB allows switching backlight colour, e.g., RGB+r = red, RGB+y = yellow, RGB+n = warm white, RGB+f = functional…
And then there is another keymap which realizes that mirroring setup, via holdKeymapLayer references replaceLayer in $onKeymapChange QT3 macro event…
See also:
If you had time to post it, and can, it would be wonderful to look at your keyboard files that implement this.
Sure! UserConfig.json (It is the QT3 map.)
Thanks for sharing master! I’ll look into it.
This is really interesting, I think there’s some really good ideas in here. Mind if I ask some stupid questions…
1 - I love the idea of using the 7890 keys as buttons, but how do you access those keys when you need to enter those numbers?
2 - “mouse/caps button alone mirrors entire keymap” - I don’t really know what this means - can you explain?
fn (right space) + a = 1
fn (right space) + s = 2
fn (right space) + d = 3
mouse (the key that would be called CapsLock on a normal keyboard) + a = ;
mouse + s = l
mouse + d = k
And this setup works for layers too, so:
mouse + fn + a = 0
mouse + fn + s = 9
Thanks @kareltucek !
I’ll play around with some of this, it’s stretching the limits of the customisation for sure, but I like a lot of these ideas!
