[Solved] Disable bluetooth when using dongle
When using the dongle, is it somehow possible to disable the Bluetooth advertisement?
I guess it is an unneeded burden on the battery (though not sure whether it’s substantial), but more importantly, I don’t really want to see my UHK pop up in Bluetooth menus of all devices nearby.
Put set bluetooth.alwaysAdvertiseHid false macro command into a macro named $onInit.
I think it should do exactly what you are after ;-).
Wouldn’t that enable BT advertising? I read that the OP wanted to disable it. Thus, set to false…?
Indeed, false.
Sweet, that did the trick indeed! Thanks! :folded_hands:
