Has anyone produced bigger tenting feet?
it seams like anyone with a little modeling skill could make these but scaleable to dif sizes.
I would love to get some stls
I only found this one:
I’m not sure if a longer one would be feasible, as the base wouldn’t be able to hold a considerably longer leg due to the amount of force.
Wow awesome thank you mlac! I will do some testing and let you know
I guess if a block is inserted in between the hinge legs after it is snapped into place, it will increase the strength considerably.
Although that would probably prevent folding the feet.
It’s already designed by someone! ![]()
