Hi!
I love the fact that my touchpad reacts to two finger gestures (scroll up/down). I didn’t find a way to configure this, though. Running fw10.0.0 on an UHK 2.
Any ideas welcome
Cheers
André
Hi!
Any ideas welcome
Cheers
André
Yes, this behavior is fixed at the moment to the scroll navigation mode.
Oh, I see. From the term “at the moment”, I conclude this is something planned. Fine for me ![]()
Edit: Just figured out how to write an $onInit-Macro that does the job ![]()
It’s more like that I am open to the idea that it might be configurable in the future…
Given you had figured out a way, what actually was the job? ![]()
Well, inverse the motion ![]()
Of course, sideways scrolling would be nice, too, as well as three finger gestures (for small fingers), as a window switcher. Anything. But it’s great enough already
Ah, I see.
There is two finger tap gesture, which can be overridden by COMMAND = set keymapAction.LAYERID.KEYID ACTION (see https://github.com/UltimateHackingKeyboard/firmware/blob/master/doc-dev/reference-manual.md).
Edit: for instance set keymapAction.base.193 keystroke a
