Are there plans to allow for wired connection functionality when connecting to the left half instead of the right?
Sorry if this has been asked before.
Do you mean for the left-half to be completely independent, or do you wish for the option to swap which side’s USB sends data to the host? If I’m not mistaken, the right half is the “brain”, and will always need to process the left-half; so an independent left-half is not likely.
Anyway, it’s definitely been discussed a few times, but I doubt it will be implemented any time soon.
Here’s the last time I remember it being mentioned:
I mean left half as the master. Thanks for the reply and link, that answers my question.
