Have you tried turning it off and back on again? JK (kinda)
Try unplugging/reconnecting the USB to see if it (UHK) comes back on. Another potential workaround could be to use the reboot macro. Idk if the UHK60 would be able to trigger macros while it’s in that state or not, but it’s worth a shot…
Anyway, it sounds like it’s probably a known issue:
It seems like the firmware update may have affected how the keyboard handles USB wake signals. Some external keyboards stop sending the proper signal to macOS after updates. Testing the keyboard on another system or trying a different USB port could help narrow it down.
Did you ever resolve this? I think I might be having the same problem. It seems like when my mac goes to sleep, the keyboard won’t wake up again. I press the keys and it’s like the keyboard has a dead battery. If I plug it into the mac then it immediately lights up and works like normal while plugged in, but as soon as I unplug it again, it immediately turns off once again.
It seems that I have to:
plug in the UHK 80 ( I have the 80 not the 60)
delete the UHK 80 from my list of bluetooth devices
then I can unplug it and it will try to find fine a bluetooth connection
I then need to pair the device with the mac again, and then after that it will work wirelessly and will wake up normally, I guess until the mac goes to sleep again?
