My left hand (gamer-side) rubber nubs on my V1 have given up on life and have broken off. I could replace them with other ones but I think that would quickly get me in the same situation. I’m thinking about having something like a rubber strip or something similar to the sides of my UHK (for a tent setup). Does anybody have recommendations? Note that I do have a palm rest and the base plate of that does stick out a bit.
Something like this should work well I think. You might need to reglue them with a stronger adhesive if the default one proves to be too weak: https://a.aliexpress.com/_EwsCYRA ![]()
(16mm half-sphere rubber feets/pads)
If you want them flat, there should be plenty to pick from, although there I can’t provide hands on experience.
